Introduzione
Use this guide to replace the motherboard.
Cosa ti serve
Using a plastic opening tool, pry the divot to the left of the camera to take off the rear case.
Use a plastic opening tool, or your fingernail to to take off the rear case by prying the divot to the left of the camera.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Using an opening tool, take off the cover for the digitizer connector.
detach the connector with a tweezer or a plastic spudger.
Altre 2 persone hanno completato questa guida.
