Salta al contenuto principale
Samsung Galaxy Light Rear Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Back Cover: passo 1, immagine 1 di 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Battery: passo 2, immagine 1 di 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Rear Facing Camera Replacement, Unscrew Midframe: passo 3, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Midframe: passo 4, immagine 1 di 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: passo 5, immagine 1 di 3 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: passo 5, immagine 2 di 3 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: passo 5, immagine 3 di 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Rear Facing Camera Replacement, Rear Facing Camera: passo 6, immagine 1 di 1
    • Use a plastic opening tool to disconnect the rear facing camera from the motherboard.
Conclusione
Geoff Wacker
Membro da: 09/30/13
89.956 Reputazione
89 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 527
