Salta al contenuto principale
Samsung Galaxy J7 v Volume Button Replacement
Cosa ti serve
  1. Samsung Galaxy J7 v Volume Button Replacement, Screen: passo 1, immagine 1 di 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 v Volume Button Replacement: passo 2, immagine 1 di 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 v Volume Button Replacement: passo 3, immagine 1 di 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 v Volume Button Replacement, Home button: passo 4, immagine 1 di 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 v Volume Button Replacement: passo 5, immagine 1 di 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 v Volume Button Replacement, Volume Button: passo 6, immagine 1 di 2 Samsung Galaxy J7 v Volume Button Replacement, Volume Button: passo 6, immagine 2 di 2
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 v Volume Button Replacement: passo 7, immagine 1 di 1
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 v Volume Button Replacement: passo 8, immagine 1 di 2 Samsung Galaxy J7 v Volume Button Replacement: passo 8, immagine 2 di 2
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 v Volume Button Replacement: passo 9, immagine 1 di 3 Samsung Galaxy J7 v Volume Button Replacement: passo 9, immagine 2 di 3 Samsung Galaxy J7 v Volume Button Replacement: passo 9, immagine 3 di 3
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 v Volume Button Replacement: passo 10, immagine 1 di 3 Samsung Galaxy J7 v Volume Button Replacement: passo 10, immagine 2 di 3 Samsung Galaxy J7 v Volume Button Replacement: passo 10, immagine 3 di 3
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 970
