Salta al contenuto principale
Samsung Galaxy J7 Vibration Motor Replacement
Cosa ti serve
  1. Samsung Galaxy J7 Vibration Motor Replacement, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy J7 Vibration Motor Replacement, Back Cover: passo 1, immagine 2 di 2
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Vibration Motor Replacement, Midframe: passo 2, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  3. Samsung Galaxy J7 Vibration Motor Replacement: passo 3, immagine 1 di 3 Samsung Galaxy J7 Vibration Motor Replacement: passo 3, immagine 2 di 3 Samsung Galaxy J7 Vibration Motor Replacement: passo 3, immagine 3 di 3
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 329
