Salta al contenuto principale
Samsung Galaxy J7 Midframe Replacement
Cosa ti serve
  1. Samsung Galaxy J7 Midframe Replacement, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy J7 Midframe Replacement, Back Cover: passo 1, immagine 2 di 2
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Midframe Replacement, Battery: passo 2, immagine 1 di 2 Samsung Galaxy J7 Midframe Replacement, Battery: passo 2, immagine 2 di 2
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
  3. Samsung Galaxy J7 Midframe Replacement, Midframe: passo 3, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  4. Samsung Galaxy J7 Midframe Replacement: passo 4, immagine 1 di 3 Samsung Galaxy J7 Midframe Replacement: passo 4, immagine 2 di 3 Samsung Galaxy J7 Midframe Replacement: passo 4, immagine 3 di 3
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,326
