Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
  1. Take off the back by pulling on the tab near the top left of the back of the device. Take off the back by pulling on the tab near the top left of the back of the device.
    • Take off the back by pulling on the tab near the top left of the back of the device.
  2. Take out the battery before unscrewing the screws. Take out the battery before unscrewing the screws.
    • Take out the battery before unscrewing the screws.
  3. Using the Phillips screwdriver bit size 000, unscrew out all 10 4.19mm screws.
    • Using the Phillips screwdriver bit size 000, unscrew out all 10 4.19mm screws.
  4. Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device. Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device. Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device.
    • Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device.
  5. Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
    • Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
  6. Make sure to pull up all of these parts in order to properly take off the next piece.
    • Make sure to pull up all of these parts in order to properly take off the next piece.
  7. Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture. Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
    • Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
  8. Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera. Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
    • Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 180
