Salta al contenuto principale
Samsung Galaxy J7 Front Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy J7 Front Facing Camera Replacement, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy J7 Front Facing Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Front Facing Camera Replacement, Midframe: passo 2, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  3. Samsung Galaxy J7 Front Facing Camera Replacement: passo 3, immagine 1 di 3 Samsung Galaxy J7 Front Facing Camera Replacement: passo 3, immagine 2 di 3 Samsung Galaxy J7 Front Facing Camera Replacement: passo 3, immagine 3 di 3
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
  4. Samsung Galaxy J7 Front Facing Camera Replacement, Front Facing Camera: passo 4, immagine 1 di 1
    • Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
  5. Samsung Galaxy J7 Front Facing Camera Replacement: passo 5, immagine 1 di 1
    • Make sure to pull up all of these parts in order to properly take off the next piece.
  6. Samsung Galaxy J7 Front Facing Camera Replacement: passo 6, immagine 1 di 2 Samsung Galaxy J7 Front Facing Camera Replacement: passo 6, immagine 2 di 2
    • Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
  7. Samsung Galaxy J7 Front Facing Camera Replacement: passo 7, immagine 1 di 2 Samsung Galaxy J7 Front Facing Camera Replacement: passo 7, immagine 2 di 2
    • Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 27
Tutti i Tempi: 473
