Salta al contenuto principale
Samsung Galaxy J3 Prime Battery and SIM Card Replacement
  1. Samsung Galaxy J3 Prime Battery and SIM Card Replacement, Battery and SIM card: passo 1, immagine 1 di 1
    • Power off your phone by holding down the power button; located on the top right-hand side of your phone for approximately 5 seconds.
    • Make sure to remove your phone charger if it is plugged in.
  2. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 2, immagine 1 di 3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 2, immagine 2 di 3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 2, immagine 3 di 3
    • Turn your phone so the back is facing up.
    • Using your fingers or a spudger, remove the cover by lifting it from the slot located on the top right-hand side underneath the volume buttons.
  3. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 3, immagine 1 di 2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 3, immagine 2 di 2
    • Remove the battery by lifting it up from the slot in the bottom right corner.
  4. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 4, immagine 1 di 3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 4, immagine 2 di 3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 4, immagine 3 di 3
    • Slide the SIM card down from the SIM card slot.
    • Make sure to firmly press down on the SIM card when sliding down, for easy removal.
  5. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 5, immagine 1 di 2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 5, immagine 2 di 2
    • Slide the new SIM card into the slot.
    • When you slide the new SIM card in, make sure to place the golden pleated side face down.
    • Now place the new battery into the battery slot by aligning it correctly with the four gold contacts.
  6. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 6, immagine 1 di 3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 6, immagine 2 di 3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: passo 6, immagine 3 di 3
    • Put the cover back by sliding it on, and firmly pressing it shut.
    • Power on your phone.
Conclusione
Aisha Bashir
Membro da: 07/01/21
133 Reputazione
1 Guida realizzata
Un commento
I need to replace the sim card slot on one of these is it individual or does it come out with the whole motherbord and what parts do I need to order?
Mitchell Hedlund - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 760
