Salta al contenuto principale
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
Cosa ti serve
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: passo 1, immagine 1 di 1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 2, immagine 1 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 2, immagine 2 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 2, immagine 3 di 3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 3, immagine 1 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 3, immagine 2 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 3, immagine 3 di 3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 4, immagine 1 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 4, immagine 2 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 4, immagine 3 di 3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 5, immagine 1 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 5, immagine 2 di 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: passo 5, immagine 3 di 3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: passo 6, immagine 1 di 2 Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: passo 6, immagine 2 di 2
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Conclusione
USF Tampa, Team S5-G5, Passmore Spring 2018 Membro di USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,222
