Introduzione
Have you ever dropped your phone and sighed with relief because the screen didn't hit the ground. You happily pick up your phone only to then be saddened by the fact that your camera lens is now shattered. Well this guide will show you the step by step process of how to replace the camera on the Samsung Galaxy J3 Luna Pro.
  1. Turn off the phone.
    • Turn off the phone.
    • Remove the back cover and battery
  2. Attach a suction cup to the screen and pry upwards.
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
    • Remove the motherboard from the mid-frame.
    • Use a spudger to flip up the retaining flaps on the front and rear camera ribbon cable ZIF sockets.
    • Pull the cables outs of the ZIF sockets.
Conclusione
Altre 2 persone hanno completato questa guida.
Jay Patel
Membro da: 29/01/2018
147 Reputazione
1 Guida realizzata
USF Tampa, Team S5-G5, Passmore Spring 2018 Membro di USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 58
Tutti i Tempi: 434
