Salta al contenuto principale
Samsung Galaxy J3 Emerge Screen Replacement
Cosa ti serve
  1. Samsung Galaxy J3 Emerge Screen Replacement, Screen: passo 1, immagine 1 di 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: passo 1, immagine 2 di 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Screen Replacement: passo 2, immagine 1 di 2 Samsung Galaxy J3 Emerge Screen Replacement: passo 2, immagine 2 di 2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Screen Replacement: passo 3, immagine 1 di 2 Samsung Galaxy J3 Emerge Screen Replacement: passo 3, immagine 2 di 2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Conclusione
Altre 6 persone hanno completato questa guida.
PJ Yebisu
Membro da: 01/24/19
256 Reputazione
1 Guida realizzata
Cal Poly, Team S19-G2, White Winter 2019 Membro di Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Membri
5 Guide realizzate
2 Commenti
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
theleachs - Replica
Gostei da aula parabens muito gratificante.
athoscost - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,049
