Salta al contenuto principale
Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement
Cosa ti serve
  1. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Screen: passo 1, immagine 1 di 3 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Screen: passo 1, immagine 2 di 3 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Screen: passo 1, immagine 3 di 3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 2, immagine 1 di 2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 2, immagine 2 di 2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 3, immagine 1 di 2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 3, immagine 2 di 2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
  4. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Motherboard: passo 4, immagine 1 di 2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Motherboard: passo 4, immagine 2 di 2
    • Remove the eleven Phillips #00 3.5mm screws.
    • If the screws get stuck when removing, try using tape to get them out. Place the adhesive side of tape on the screws and pull the tape off the spot.
  5. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 5, immagine 1 di 1
    • Turn the phone over and push down where the battery was.
    • There will be a loud clicking noise when applying pressure.
  6. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 6, immagine 1 di 1
    • Insert the iFixit Opening Pick between the motherboard and the panel.
    • Work the iFixit Opening Pick around the outside of the motherboard.
  7. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 7, immagine 1 di 2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 7, immagine 2 di 2
    • Pry the motherboard away from the phone using your hand.
  8. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Home Button and Audio Jack: passo 8, immagine 1 di 1
    • Slide the home button to the left to pop it off.
  9. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 9, immagine 1 di 1
    • Remove the connector where the home button was using the iFixit Opening Pick.
  10. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 10, immagine 1 di 1
    • Lift up the connector and push it through the motherboard by following the ribbon.
  11. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 11, immagine 1 di 2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: passo 11, immagine 2 di 2
    • Follow the ribbon and gently pop the audio port out using the iFixit Opening Pick.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S19-G2, White Winter 2019 Membro di Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,449
