Salta al contenuto principale
Samsung Galaxy J3 Eclipse Home Button Replacement
Cosa ti serve
  1. Samsung Galaxy J3 Eclipse Home Button Replacement, Display Assembly: passo 1, immagine 1 di 1
    • Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
    • Do not apply heat to any one edge of the phone for longer than a few seconds. Instead, use a continuous motion around the phone's edges.
  2. Samsung Galaxy J3 Eclipse Home Button Replacement: passo 2, immagine 1 di 2 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
    • Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
    • When using the pry tool, do not use too much force or the phone's internals could be damaged.
    • Do not insert your tool more than 1cm into the top edge of the phone to avoid damaging the fragile cables.
  3. Samsung Galaxy J3 Eclipse Home Button Replacement: passo 3, immagine 1 di 3 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 3, immagine 2 di 3 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 3, immagine 3 di 3
    • Gently lift lower side and loosen all edges to hinge screen up from bottom.
    • Do not try to completely remove the display from the frame yet. Simply try to loosen up all the edges.
  4. Samsung Galaxy J3 Eclipse Home Button Replacement: passo 4, immagine 1 di 3 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 4, immagine 2 di 3 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 4, immagine 3 di 3
    • Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
  5. Samsung Galaxy J3 Eclipse Home Button Replacement: passo 5, immagine 1 di 3 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 5, immagine 2 di 3 Samsung Galaxy J3 Eclipse Home Button Replacement: passo 5, immagine 3 di 3
    • Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
    • Clean the residue from the phone edges before re-assembling phone with new screen.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 477
