Salta al contenuto principale
Samsung Galaxy J1 Midframe Replacement
Cosa ti serve
  1. Samsung Galaxy J1 Midframe Replacement, Midframe: passo 1, immagine 1 di 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Midframe Replacement: passo 2, immagine 1 di 2 Samsung Galaxy J1 Midframe Replacement: passo 2, immagine 2 di 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Midframe Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Midframe Replacement: passo 4, immagine 1 di 3 Samsung Galaxy J1 Midframe Replacement: passo 4, immagine 2 di 3 Samsung Galaxy J1 Midframe Replacement: passo 4, immagine 3 di 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
Conclusione
Altre 6 persone hanno completato questa guida.
Sean Kramer
Membro da: 02/14/18
1.452 Reputazione
6 Guide realizzate
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,098
