Introduzione
The goal of this guide is to demonstrate how to replace the motherboard of a Samsung Galaxy Grand Prime. This replacement is needed if you can't find anything else wrong with your phone, but it still won't work. No special skills are required for this replacement. The successful replacement of the motherboard will ensure that the phone will be able to boot up properly if done correctly.
Cosa ti serve
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Hello: Do i have to buy and or replace the audio jack?? If so is it connected by wires, or do i just unplug the audio jack n rreplace it with a new one????
If i am to just put a new audio jack in, where can i buy one to put in my phone??
Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
Remove the motherboard and unhook the ribbon cable clip to the back camera.
Sir delivery hoga or price kitnaa
Altre 86 persone hanno completato questa guida.
12 Commenti
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
My said unit was suddenly turned-off. What may possible cause for this problem? Can it be fix?
My said unit was suddenly turned-off and it can't turned back as I turn it on back. Can this be fix? What cause this problem?
where can i buy samsung j7 prime motherboard .?pls advise..thanks
i will flash my phone g532f i have forget my email can i djump it ?
Thanks so much. I was getting seriously annoyed. This worked for me. However, I'll be getting another battery just in case. This helped big
Ana - Replica
