Introduzione
This guide is needed when you have a faulty charging port.
Cosa ti serve
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
Altre 33 persone hanno completato questa guida.
