Salta al contenuto principale
Samsung Galaxy Grand Prime Micro USB Port Replacement
Cosa ti serve
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: passo 2, immagine 1 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: passo 2, immagine 2 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: passo 2, immagine 3 di 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: passo 3, immagine 1 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: passo 3, immagine 2 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: passo 3, immagine 3 di 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 4, immagine 2 di 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 5, immagine 2 di 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: passo 6, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: passo 6, immagine 2 di 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: passo 7, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: passo 7, immagine 2 di 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: passo 9, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: passo 9, immagine 2 di 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 10, immagine 1 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 10, immagine 2 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 10, immagine 3 di 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: passo 11, immagine 2 di 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: passo 12, immagine 1 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: passo 12, immagine 2 di 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: passo 12, immagine 3 di 3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
Conclusione
Altre 35 persone hanno completato questa guida.
Kyle Ruff
Membro da: 02/04/16
6.851 Reputazione
5 Guide realizzate
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro di USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 35,422
