Salta al contenuto principale
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
Cosa ti serve
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: passo 2, immagine 1 di 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: passo 2, immagine 2 di 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: passo 2, immagine 3 di 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: passo 3, immagine 1 di 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: passo 3, immagine 2 di 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: passo 3, immagine 3 di 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 4, immagine 2 di 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: passo 5, immagine 2 di 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: passo 6, immagine 1 di 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: passo 6, immagine 2 di 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Conclusione
Altre 30 persone hanno completato questa guida.
Kyle Ruff
Membro da: 02/04/16
6.749 Reputazione
5 Guide realizzate
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro di USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Membri
12 Guide realizzate
3 Commenti
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - Replica
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - Replica
How to me a memory card a default storage on grand prime
Ayandaundetsco - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 48
Tutti i Tempi: 36,057
