Salta al contenuto principale
Samsung Galaxy Grand Prime Earpiece Speaker Replacement
Cosa ti serve
  1. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: passo 1, immagine 1 di 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: passo 1, immagine 2 di 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: passo 2, immagine 1 di 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: passo 2, immagine 2 di 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: passo 2, immagine 3 di 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: passo 3, immagine 1 di 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: passo 3, immagine 2 di 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: passo 3, immagine 3 di 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: passo 4, immagine 2 di 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: passo 5, immagine 2 di 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Earpiece Speaker: passo 6, immagine 1 di 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Earpiece Speaker: passo 6, immagine 2 di 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  7. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently pull on the connector with the tweezers until the speaker comes off.
Conclusione
Altre 23 persone hanno completato questa guida.
Kyle Ruff
Membro da: 02/04/16
6.749 Reputazione
5 Guide realizzate
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro di USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 39
Tutti i Tempi: 11,792
