Salta al contenuto principale
Samsung Galaxy Gear Display Housing Replacement
Cosa ti serve
  1. Samsung Galaxy Gear Display Housing Replacement, Display Housing: passo 1, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Housing Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Housing Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Gear Display Housing Replacement: passo 3, immagine 2 di 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
Conclusione
Dalt Lasell
Membro da: 04/12/16
543 Reputazione
2 Guide realizzate
Cal Poly, Team 1-9, Maness Spring 2016 Membro di Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,279
