Introduzione
You will be learning how to replace the motherboard.
Cosa ti serve
Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
Use the plastic removal tool to work pry the mid-frame from the device.
Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place.
Altre 5 persone hanno completato questa guida.
