Salta al contenuto principale
Samsung Galaxy Fame S6812i Midframe Replacement
Cosa ti serve
  1. Samsung Galaxy Fame S6812i Midframe Replacement, Remove back cover: passo 1, immagine 1 di 1
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Samsung Galaxy Fame S6812i Midframe Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Fame S6812i Midframe Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Fame S6812i Midframe Replacement: passo 2, immagine 3 di 3
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. Samsung Galaxy Fame S6812i Midframe Replacement: passo 3, immagine 1 di 1
    • Remove the battery with plastic opening tool
  4. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: passo 4, immagine 1 di 2 Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: passo 4, immagine 2 di 2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Midframe Replacement, Final step: passo 5, immagine 1 di 1
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
Conclusione
Charles
Membro da: 10/07/14
133 Reputazione
2 Guide realizzate
USF Tampa, Team 8-2, Leahy Fall 2014 Membro di USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 592
