Salta al contenuto principale
Samsung Galaxy Fame S6812i Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: passo 1, immagine 1 di 1
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: passo 2, immagine 1 di 1
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: passo 3, immagine 1 di 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: passo 3, immagine 2 di 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: passo 3, immagine 3 di 3
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: passo 4, immagine 1 di 2 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: passo 4, immagine 2 di 2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: passo 5, immagine 1 di 1
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Conclusione
Altre 6 persone hanno completato questa guida.
Charles
Membro da: 10/07/14
133 Reputazione
2 Guide realizzate
USF Tampa, Team 8-2, Leahy Fall 2014 Membro di USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,004
