Salta al contenuto principale
Samsung Galaxy Express 3 Back and Recent Apps button Replacement
Cosa ti serve
  1. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 2, immagine 3 di 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: passo 3, immagine 1 di 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: passo 3, immagine 2 di 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 4, immagine 1 di 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 5, immagine 2 di 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: passo 6, immagine 3 di 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
  7. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): passo 7, immagine 1 di 2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): passo 7, immagine 2 di 2
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 574
