Cosa ti serve
Flip the phone over and use your fingernail or an opening tool to remove the back cover.
Altre 90 persone hanno completato questa guida.
11 Commenti
I bought it on Ebay...
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Nor do they show how the new digitizer plugs in...
Magkano po ang magagastos lcd and touch po ung papalitan
Is the Potentially Dangerous part when you work with the glass? Just curious if there was some other hidden danger?
Jup, it's only because you work with broken glass ;)
I have 2 devicies.
#1 broken LCD+digi
#2 dead with fine LCD+digi
Can I swap whole screen (LCD+digi) together with frame?
Never tried, but i guess you could just stop at step 9...
Let me know if it worked
I own and use a core prime as my phone, it has a shattered screen, verizon wont replace it because it was a warrentty replacement for my kyocera brigadir that i dropped in the ocean, it works again btw just a bit slower, but i cant afford a new phone, and i cant deal with the glass splinters any more, i dont want to spend more then i have to, are some of these required things actually needed? Like the seperation tools, can i do the same thing with say an automotive trim tool(already have one)? It looks similar at the prying tip. Maybe a high end hair dryer instead of a heat gun? (My gf has one i can use). My true goal is to spend only the cost of the replacement parts, as i do not currently have a steady income. Thanks in advance for any advise.
