Salta al contenuto principale
Samsung Galaxy Core Prime Home Button Replacement
Cosa ti serve
  1. Samsung Galaxy Core Prime Home Button  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Home Button  Replacement: passo 2, immagine 1 di 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Home Button  Replacement: passo 3, immagine 1 di 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Home Button  Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Core Prime Home Button  Replacement: passo 4, immagine 2 di 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Home Button  Replacement: passo 5, immagine 1 di 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Home Button  Replacement, Home Button: passo 6, immagine 1 di 1
    • Use your thumb to remove the sim card.
  7. Samsung Galaxy Core Prime Home Button  Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Core Prime Home Button  Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws that secure the midframe.
  8. Samsung Galaxy Core Prime Home Button  Replacement: passo 8, immagine 1 di 1
    • Heat the frame with a hair dryer or heat gun. Do this until the adhesive is loosened.
    • Take care when using these heating tools.
  9. Samsung Galaxy Core Prime Home Button  Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    Compra
  10. Samsung Galaxy Core Prime Home Button  Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Core Prime Home Button  Replacement: passo 10, immagine 2 di 2
    • Disconnect the LCD screen/touch screen ribbon from the motherboard using tweezers.
  11. Samsung Galaxy Core Prime Home Button  Replacement: passo 11, immagine 1 di 1
    iFixit Opening Tool
    $1.99
    Compra
  12. Samsung Galaxy Core Prime Home Button  Replacement: passo 12, immagine 1 di 1
    • Heat the sides of the screen with a heat gun or hair dryer.
  13. Samsung Galaxy Core Prime Home Button  Replacement: passo 13, immagine 1 di 1
    iFixit Opening Tool
    $1.99
    Compra
    • Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
  14. Samsung Galaxy Core Prime Home Button  Replacement: passo 14, immagine 1 di 1
    • Use tweezers to remove the home button.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,336
