Salta al contenuto principale
Samsung Galaxy Core Main and Front Cameras Replacement
Cosa ti serve
Panoramica Video
  1. Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: passo 1, immagine 1 di 2 Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: passo 1, immagine 2 di 2
    • Switch-off the phone.
    • Remove the Battery cover and the battery.
    • Remove an inserted SIM and Memory cards.
  2. Samsung Galaxy Core Main and Front Cameras Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Core Main and Front Cameras Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Core Main and Front Cameras Replacement: passo 2, immagine 3 di 3
    • Remove 9x Phillips screws.
    • With a plastic tool remove the Back cover.
    • The Vibrator is on the other side of the back cover
  3. Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: passo 3, immagine 1 di 3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: passo 3, immagine 2 di 3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: passo 3, immagine 3 di 3
    • Disconnect one by one:
    • Earpiece/Loudspeaker/Audio Jack connector module flex cable
    • LCD Display flex cable
    • Charging Dock/Antenna/Mic module flex cable
    • Coaxial Antenna cable
    • Carefully remove the Logic Board.
  4. Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: passo 4, immagine 1 di 3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: passo 4, immagine 2 di 3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: passo 4, immagine 3 di 3
    • Main / Rear Camera
    • Front Camera
    • With a plastic tool open the Camera flex cable connector.
    • Carefully remove the camera.
Conclusione
Altre 7 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
192.056 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.525 Guide realizzate
3 Commenti
Hi, I have galaxy win and the front camera is too bad in quality, i want to replace front camera with galaxy core front camera which is very descent in compare to galaxy win. Please suggest
My email Id: shaikhyassar@gmail.com
Yassar Shaikh - Replica
اكتب عربي
Mjd Mjd - Replica
My mobile Sony m2 my camera low quality... Can I do anything for this problem??!
Mjd Mjd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,533
