Salta al contenuto principale
Samsung Galaxy Camera Lens or Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: passo 1, immagine 1 di 1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 3, immagine 2 di 2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 4, immagine 3 di 3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 5, immagine 2 di 2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Camera Lens or Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
Conclusione
Altre 8 persone hanno completato questa guida.
Keith Lipking
Membro da: 09/26/15
359 Reputazione
1 Guida realizzata
IUPUI, Team 2-3, Wilson Fall 2015 Membro di IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Membri
4 Guide realizzate
2 Commenti
Would love a video of this, as well.
David CrossmN - Replica
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,313
