Salta al contenuto principale
Samsung Galaxy Camera Lens and Motherboard Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-6 provengono da una guida contrassegnata come in corso.
    Samsung Galaxy Camera Lens and Motherboard Replacement, Screen: passo 1, immagine 1 di 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 2, immagine 1 di 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 3, immagine 1 di 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Camera Lens and Motherboard Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Camera Lens and Motherboard Replacement: passo 4, immagine 3 di 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 5, immagine 1 di 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 6, immagine 1 di 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Lens and Motherboard Replacement, Lens and Motherboard: passo 7, immagine 1 di 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 8, immagine 1 di 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 9, immagine 1 di 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Lens and Motherboard Replacement: passo 10, immagine 1 di 1
    • Lift the motherboard and lens out of the case.
Conclusione
Altre 10 persone hanno completato questa guida.
Richard Hicks
Membro da: 01/13/15
1.262 Reputazione
4 Guide realizzate
USF Tampa, Team 1-3, Sullivan Winter 2015 Membro di USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Membri
4 Guide realizzate
Un commento
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
Sam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 5,064
