Salta al contenuto principale
Samsung Galaxy Camera Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Camera Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: passo 2, immagine 1 di 1
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Camera Battery Replacement: passo 3, immagine 2 di 2
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Camera Battery Replacement: passo 4, immagine 2 di 2
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
Conclusione
These steps follow completely: there is no need to reverse the order of steps to reassemble.
Altre 8 persone hanno completato questa guida.
Derek Brown
Membro da: 10/24/15
168 Reputazione
1 Guida realizzata
IUPUI, Team 2-3, Wilson Fall 2015 Membro di IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 77
Tutti i Tempi: 1,933
