Introduzione
Remove the speaker/rear camera assembly from the Samsung Galaxy Attain 4G. This assembly includes the vibrator, rear-facing camera, flash, and loudspeaker.
Begin by turn the device over to it's back, with the screen facing down.
  • Begin by turn the device over to it's back, with the screen facing down.
Aggiungi Commento
At the top of the device there is a small notch that is used to remove the battery door.
  • At the top of the device there is a small notch that is used to remove the battery door.
  • Using a pry tool or your fingernail, pry off the battery door from the main housing.
Aggiungi Commento
  • Place the battery door to the side.
  • Using a pry tool or your fingernail, pry the battery up towards you.
  • You have now removed the battery!
Aggiungi Commento
  • Make sure when replacing the battery that the arrow on the bottom is facing down.
Aggiungi Commento
  • Remove the 6 Phillips head screws that hold the rear housing in place.
Aggiungi Commento
  • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Aggiungi Commento
  • Lift the rear housing from the display assembly.
Aggiungi Commento
  • Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
Aggiungi Commento
  • Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
Aggiungi Commento
  • Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
Aggiungi Commento
  • After removing both flex cables, slowly move the logic board to the left of the screen assembly.
  • Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
Aggiungi Commento
  • Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
Aggiungi Commento
  • You have now removed the logic board from the display assembly.
Aggiungi Commento
  • Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable.
Aggiungi Commento
  • Flip the logic board to the front, and using a spudger/plastic pry tool to push the tension clip away from the board that holds the speaker/rear camera.
Aggiungi Commento
  • Flipping the board back over, remove the speaker/rear camera by lifting from the right side as shown.
  • Be careful not to rip the ribbon cable when you disconnect the speaker/rear camera cable connector.
Aggiungi Commento
  • The speaker/rear camera has now been removed from the board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Josh Forester
Membro da: 28/11/2010
2.328 Reputazione
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 135
