Salta al contenuto principale
Samsung Galaxy Attain 4G Front Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Attain 4G Front Camera Replacement, Placement: passo 1, immagine 1 di 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Door Removal: passo 2, immagine 1 di 2 Samsung Galaxy Attain 4G Front Camera Replacement, Battery Door Removal: passo 2, immagine 2 di 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: passo 3, immagine 1 di 3 Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: passo 3, immagine 2 di 3 Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: passo 3, immagine 3 di 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Front Camera Replacement, Heads Up!: passo 4, immagine 1 di 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Front Camera Replacement, Screw Removal: passo 5, immagine 1 di 1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Front Camera Replacement, Prying: passo 6, immagine 1 di 1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Front Camera Replacement, Remove Housing: passo 7, immagine 1 di 1
    • Lift the rear housing from the display assembly.
  8. Samsung Galaxy Attain 4G Front Camera Replacement, Logic Board: passo 8, immagine 1 di 2 Samsung Galaxy Attain 4G Front Camera Replacement, Logic Board: passo 8, immagine 2 di 2
    • Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
  9. Samsung Galaxy Attain 4G Front Camera Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Attain 4G Front Camera Replacement: passo 9, immagine 2 di 2
    • Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
  10. Samsung Galaxy Attain 4G Front Camera Replacement: passo 10, immagine 1 di 1
    • Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
  11. Samsung Galaxy Attain 4G Front Camera Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Attain 4G Front Camera Replacement: passo 11, immagine 2 di 2
    • After removing both flex cables, slowly move the logic board to the left of the screen assembly.
    • Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
  12. Samsung Galaxy Attain 4G Front Camera Replacement: passo 12, immagine 1 di 1
    • Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
  13. Samsung Galaxy Attain 4G Front Camera Replacement: passo 13, immagine 1 di 2 Samsung Galaxy Attain 4G Front Camera Replacement: passo 13, immagine 2 di 2
    • You have now removed the logic board from the display assembly.
  14. Samsung Galaxy Attain 4G Front Camera Replacement, Front Camera: passo 14, immagine 1 di 1
    • Using a spudger/plastic pry tool lift the brown ZIF tab on the front-facing camera connector.
    • Do not pry at the black part, as this will damage the connector on the board.
  15. Samsung Galaxy Attain 4G Front Camera Replacement: passo 15, immagine 1 di 1
    • Carefully pull the camera out of it's connector and set to the side.
Conclusione
Altre 3 persone hanno completato questa guida.
Josh Forester
Membro da: 11/28/10
2.505 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 347
