Salta al contenuto principale
Samsung Galaxy Attain 4G Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Attain 4G Battery Replacement, Placement: passo 1, immagine 1 di 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: passo 2, immagine 1 di 2 Samsung Galaxy Attain 4G Battery Replacement, Battery Door Removal: passo 2, immagine 2 di 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: passo 3, immagine 1 di 3 Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: passo 3, immagine 2 di 3 Samsung Galaxy Attain 4G Battery Replacement, Battery Removal: passo 3, immagine 3 di 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Battery Replacement, Heads Up!: passo 4, immagine 1 di 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
Conclusione
Josh Forester
Membro da: 11/28/10
2.497 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 387
