Salta al contenuto principale
Samsung Galaxy Amp 2 Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Amp 2 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Amp 2 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Amp 2 Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Amp 2 Motherboard Replacement: passo 2, immagine 3 di 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Motherboard Replacement, Screen: passo 3, immagine 1 di 3 Samsung Galaxy Amp 2 Motherboard Replacement, Screen: passo 3, immagine 2 di 3 Samsung Galaxy Amp 2 Motherboard Replacement, Screen: passo 3, immagine 3 di 3
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Motherboard Replacement: passo 4, immagine 1 di 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Motherboard Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Amp 2 Motherboard Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Amp 2 Motherboard Replacement: passo 5, immagine 3 di 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Samsung Galaxy Amp 2 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Samsung Galaxy Amp 2 Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
Conclusione
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 774
