Salta al contenuto principale
Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: passo 1, immagine 1 di 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: passo 1, immagine 2 di 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: passo 1, immagine 3 di 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: passo 2, immagine 1 di 2 Samsung Galaxy Alpha microSIM Card Replacement, Battery: passo 2, immagine 2 di 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: passo 3, immagine 1 di 1
    • Remove your Micro SIM card from the slot shown.
Conclusione
Altre 11 persone hanno completato questa guida.
Tyler
Membro da: 01/22/15
769 Reputazione
1 Guida realizzata
Cal Poly, Team 20-17, Maness Winter 2015 Membro di Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,598
