Salta al contenuto principale
Samsung Galaxy Alpha Back Cover Replacement
  1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: passo 1, immagine 1 di 3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: passo 1, immagine 2 di 3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: passo 1, immagine 3 di 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
Conclusione
To replace the cover, realign the cover with the device and gently press down until you hear the connections click.
Altre 13 persone hanno completato questa guida.
Sarah
Membro da: 01/22/15
946 Reputazione
2 Guide realizzate
Cal Poly, Team 20-17, Maness Winter 2015 Membro di Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 4,010
