Salta al contenuto principale
Panoramica Video
  1. Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: passo 1, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: passo 1, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: passo 1, immagine 3 di 3
    • Display Touch Screen Digitizer Assembly with Frame for Samsung Galaxy A50
  2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: passo 2, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: passo 2, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: passo 2, immagine 3 di 3
    • Heat up the back cover to loosen the adhesive.
    • To separate the back cover use a Suction Cup and plastic tools.
  3. Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: passo 3, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: passo 3, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: passo 3, immagine 3 di 3
    • Remove the SIM tray.
    • Remove the Philips Screws.
    • Again use plastic tools to separate the middle frame.
  4. Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: passo 4, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: passo 4, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: passo 4, immagine 3 di 3
    • First disconnect the Battery.
    • Test the new spare part before the installation.
  5. Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: passo 5, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: passo 5, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: passo 5, immagine 3 di 3
    • Disconnect and remove the Main Flex Cable.
    • Remove the black Philips screw, it's shorter then the middle frame screws.
    • Disconnect the coaxial antenna cable.
    • Now you can remove the logic board.
  6. Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: passo 6, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: passo 6, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: passo 6, immagine 3 di 3
    • First remove the Fingerprint sensor.
    • The screws for the Fingerprint are shorter.
    • It's better to use hot air before to disassemble the sub-board.
    • Reminder - only plastic tools :)
  7. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: passo 7, immagine 1 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: passo 7, immagine 2 di 3 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: passo 7, immagine 3 di 3
    • Again, hot air, plastic tools and very slowly remove the battery.
  8. Samsung Galaxy A50 Display Assembly with Frame Replacement: passo 8, immagine 1 di 1
    • All's Well That Ends Well
Conclusione
ZFix
Membro da: 09/12/2013
185.706 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
307 Membri
1.128 Guide realizzate
Un commento
The frame I bought doesn't have the place for earspeaker surrounded by little "walls", so it's very loose and doesn't have contact with the board. Anyone experienced this?
knezi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 25
Ultimi 7 Giorni: 122
Ultimi 30 Giorni: 472
Tutti i Tempi: 6,806
