Salta al contenuto principale
Samsung Galaxy A41 Display Replacement
    • Found this video on how to do the repair. Worked perfectly.
  1. Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.16
    • Prepare the necessary repair materials. Make sure you have everything before you start.
    • Make sure you are working with the right model. In this case, it is a Samsung Galaxy A41 (SM-A415F), in white.
    • In this video, the screen was damaged by a blow to the left side. This requires a complete display replacement.
    • You need a new replacement display for your Samsung Galaxy A41. If you want the same display quality again, you need to make sure that it is a Super AMOLED display.
  2. Attrezzo utilizzato in questo passaggio:
    Heat Gun
    $24.99
    • Clean the surface and remove any adhesive residue to ensure that the new screen is clean and flush.
    • Carefully position the new display so that you can reconnect all the cables.
    • Turn on the device and check if the new display is working correctly.
Conclusione
Congratulations! You've done it and successfully replaced the display on your Samsung Galaxy A41.
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
riiedl95
Membro da: 08/25/21
143 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 129
Tutti i Tempi: 4,617
