Introduzione
Samsung A20e - Broken Screen Replacement
Cosa ti serve
Panoramica Video
This is Display Touch Screen Assembly with Frame
Remove the SIM tray
To remove the back cover use a plastic opening tool
When you remove the back cover, press the Touch ID to unstick it from the back cover
With a Phillips Screwdriver remove all the screws
With a Plastic Opening Tool:
Remove the Antenna Assembly
Disconnect and remove the Touch ID Fingerprint Sensor
Remove the Logic Board Plastic Cover
Remove the Sup-board Plastic Cover
Disconnect the Sup-board Flex Cable
Disconnect the Coaxial Antenna Cables. Do it very carefully because you can easily damage them
Remove the Sup-board Flex Cable
Disconnect the Volume buttons Flex Cable
Gently remove the Logic board. Be careful for the cameras
Use Hot air to soften the adhesive and gently remove the sup-bord
To remove the Battery use a few drops of alcohol and warm the device.
Now you have to transfer:
Receiber
Vibromotor
Loudspeacker
Remove the transport tapes from:
Silicon Thermal Pad
Front Camera Hole
Altre 21 persone hanno completato questa guida.
