Salta al contenuto principale
Samsung Exhibit II 4G Rear Facing Camera Replacement
Cosa ti serve
  1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 2, immagine 1 di 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Rear Facing Camera Replacement, Top Rear Housing Cover: passo 3, immagine 1 di 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 5, immagine 1 di 2 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 5, immagine 2 di 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 6, immagine 1 di 3 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 6, immagine 2 di 3 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 6, immagine 3 di 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Rear Facing Camera Replacement, Midframe: passo 7, immagine 1 di 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 8, immagine 1 di 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 9, immagine 1 di 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 10, immagine 1 di 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Rear Facing Camera Replacement, Rear Facing Camera: passo 11, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  12. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 12, immagine 1 di 2 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 12, immagine 2 di 2
    • Remove camera from square housing.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 372
