Salta al contenuto principale
Samsung Exhibit II 4G Motherboard Replacement
Cosa ti serve
  1. Samsung Exhibit II 4G Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Motherboard Replacement: passo 2, immagine 1 di 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Motherboard Replacement, Top Rear Housing Cover: passo 3, immagine 1 di 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Motherboard Replacement: passo 5, immagine 1 di 2 Samsung Exhibit II 4G Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Motherboard Replacement: passo 6, immagine 1 di 3 Samsung Exhibit II 4G Motherboard Replacement: passo 6, immagine 2 di 3 Samsung Exhibit II 4G Motherboard Replacement: passo 6, immagine 3 di 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Motherboard Replacement, Midframe: passo 7, immagine 1 di 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Motherboard Replacement: passo 8, immagine 1 di 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Motherboard Replacement: passo 9, immagine 1 di 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Motherboard Replacement: passo 10, immagine 1 di 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: passo 11, immagine 1 di 2 Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: passo 11, immagine 2 di 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Motherboard Replacement: passo 12, immagine 1 di 2 Samsung Exhibit II 4G Motherboard Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Motherboard Replacement, Rear Facing Camera: passo 13, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Motherboard Replacement: passo 14, immagine 1 di 2 Samsung Exhibit II 4G Motherboard Replacement: passo 14, immagine 2 di 2
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Motherboard Replacement, Motherboard: passo 15, immagine 1 di 3 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: passo 15, immagine 2 di 3 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: passo 15, immagine 3 di 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Motherboard Replacement: passo 16, immagine 1 di 3 Samsung Exhibit II 4G Motherboard Replacement: passo 16, immagine 2 di 3 Samsung Exhibit II 4G Motherboard Replacement: passo 16, immagine 3 di 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 633
