Salta al contenuto principale
Samsung Exhibit II 4G Display Assembly Replacement
Cosa ti serve
  1. Samsung Exhibit II 4G Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Display Assembly Replacement: passo 2, immagine 1 di 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Display Assembly Replacement, Top Rear Housing Cover: passo 3, immagine 1 di 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Display Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Display Assembly Replacement: passo 5, immagine 1 di 2 Samsung Exhibit II 4G Display Assembly Replacement: passo 5, immagine 2 di 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Display Assembly Replacement: passo 6, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 6, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 6, immagine 3 di 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Display Assembly Replacement, Midframe: passo 7, immagine 1 di 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Display Assembly Replacement: passo 8, immagine 1 di 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Display Assembly Replacement: passo 9, immagine 1 di 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Display Assembly Replacement: passo 10, immagine 1 di 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Display Assembly Replacement, Vibration Motor: passo 11, immagine 1 di 2 Samsung Exhibit II 4G Display Assembly Replacement, Vibration Motor: passo 11, immagine 2 di 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Display Assembly Replacement: passo 12, immagine 1 di 2 Samsung Exhibit II 4G Display Assembly Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Display Assembly Replacement, Rear Facing Camera: passo 13, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Display Assembly Replacement: passo 14, immagine 1 di 2 Samsung Exhibit II 4G Display Assembly Replacement: passo 14, immagine 2 di 2
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: passo 15, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: passo 15, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: passo 15, immagine 3 di 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Display Assembly Replacement: passo 16, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 16, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 16, immagine 3 di 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
  17. Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: passo 17, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: passo 17, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: passo 17, immagine 3 di 3
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
  18. Samsung Exhibit II 4G Display Assembly Replacement: passo 18, immagine 1 di 2 Samsung Exhibit II 4G Display Assembly Replacement: passo 18, immagine 2 di 2
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
  19. Samsung Exhibit II 4G Display Assembly Replacement: passo 19, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 19, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 19, immagine 3 di 3
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
  20. Samsung Exhibit II 4G Display Assembly Replacement: passo 20, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 20, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 20, immagine 3 di 3
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
  21. Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: passo 21, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: passo 21, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: passo 21, immagine 3 di 3
    • The the flat end of a spudger between componet and frame.
    • Use the the spudger to lift the componet from the frame.
  22. Samsung Exhibit II 4G Display Assembly Replacement: passo 22, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 22, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 22, immagine 3 di 3
    • Insert the spudger between blue flim and the back of the LCD.
    • Using the spudger lift blue film away from LCD.
  23. Samsung Exhibit II 4G Display Assembly Replacement: passo 23, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 23, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 23, immagine 3 di 3
    • Notice ribbon cable slides under the tan square component.
  24. Samsung Exhibit II 4G Display Assembly Replacement: passo 24, immagine 1 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 24, immagine 2 di 3 Samsung Exhibit II 4G Display Assembly Replacement: passo 24, immagine 3 di 3
    • Insert a plastic opening tool between LCD and Digitizer screen.
    • Use plastic opening tool to pry and lift the LCD from the glass screen.
    • Adhesive material around edge of LCD.
  25. Samsung Exhibit II 4G Display Assembly Replacement: passo 25, immagine 1 di 2 Samsung Exhibit II 4G Display Assembly Replacement: passo 25, immagine 2 di 2
    • Lift LCD away from digitizer screen.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 775
