Salta al contenuto principale
Samsung Eternity Microphone Replacement
Cosa ti serve
    • Remove the back battery cover.
  1. Samsung Eternity Microphone Replacement: passo 2, immagine 1 di 1
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Microphone Replacement: passo 3, immagine 1 di 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Microphone Replacement: passo 4, immagine 1 di 2 Samsung Eternity Microphone Replacement: passo 4, immagine 2 di 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Microphone Replacement, Motherboard: passo 5, immagine 1 di 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Microphone Replacement: passo 6, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 6, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 6, immagine 3 di 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Microphone Replacement: passo 7, immagine 1 di 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Microphone Replacement: passo 8, immagine 1 di 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Microphone Replacement: passo 9, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 9, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 9, immagine 3 di 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Microphone Replacement: passo 10, immagine 1 di 1
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Microphone Replacement, Digitizer and Screen: passo 11, immagine 1 di 1
    • Flip phone over so you are looking at the front screen of the phone. (The back is already taken off and parts removed)
  11. Samsung Eternity Microphone Replacement: passo 12, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 12, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 12, immagine 3 di 3
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone. This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Microphone Replacement: passo 13, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 13, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 13, immagine 3 di 3
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
  13. Samsung Eternity Microphone Replacement, Microphone: passo 14, immagine 1 di 1
    • Pop the microphone up and out of its small housing.
  14. Samsung Eternity Microphone Replacement: passo 15, immagine 1 di 1
    • Peel up the black tape on the bottom of the back case.
  15. Samsung Eternity Microphone Replacement: passo 16, immagine 1 di 1
    • Use the spudger to release the front buttons from the phones frame.
    • Don't try and pull the front buttons completely away from the phone. There are clips that still are holding them to the phone.
  16. Samsung Eternity Microphone Replacement: passo 17, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 17, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 17, immagine 3 di 3
    • Use the spudger to remove three plastic lasso hooks that are holding the front buttons to the case.
    • The front button plastic assembly should come right off.
  17. Samsung Eternity Microphone Replacement: passo 18, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to release the button logic board away from the phone's casing.
    • Do not try and completely remove the component. There are logic ribbons that need to be guided through the phone's back casing.
  18. Samsung Eternity Microphone Replacement: passo 19, immagine 1 di 1
    • You should be able to see two cables connected to the front button board.
    • Carefully slide these two cables through their respective holes in the body of the camera.
  19. Samsung Eternity Microphone Replacement: passo 20, immagine 1 di 1
    • The front button board should slide out. At this time you can replace the button/microphone component.
Conclusione
Cal Poly, Team 15-11, Regan Spring 2011 Membro di Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,087
