Salta al contenuto principale
Samsung Eternity Microphone Replacement
Cosa ti serve
    • Remove the back battery cover.
    Chiedi a FixBot
  1. Samsung Eternity Microphone Replacement: passo 2, immagine 1 di 1
    • Using a nylon spudger, remove the phone's battery.
    Chiedi a FixBot
  2. Samsung Eternity Microphone Replacement: passo 3, immagine 1 di 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
    Chiedi a FixBot
  3. Samsung Eternity Microphone Replacement: passo 4, immagine 1 di 2 Samsung Eternity Microphone Replacement: passo 4, immagine 2 di 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
    Chiedi a FixBot
  4. Samsung Eternity Microphone Replacement, Motherboard: passo 5, immagine 1 di 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
    Chiedi a FixBot
  5. Samsung Eternity Microphone Replacement: passo 6, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 6, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 6, immagine 3 di 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
    Chiedi a FixBot
  6. Samsung Eternity Microphone Replacement: passo 7, immagine 1 di 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
    Chiedi a FixBot
  7. Samsung Eternity Microphone Replacement: passo 8, immagine 1 di 1
    • Peel the button sensor on the side of the motherboard off of the case.
    Chiedi a FixBot
  8. Samsung Eternity Microphone Replacement: passo 9, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 9, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 9, immagine 3 di 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
    Chiedi a FixBot
  9. Samsung Eternity Microphone Replacement: passo 10, immagine 1 di 1
    • You have successfully removed the motherboard from the phone.
    Chiedi a FixBot
  10. Samsung Eternity Microphone Replacement, Digitizer and Screen: passo 11, immagine 1 di 1
    • Flip the phone over so you are looking at the front screen of the phone.
    Chiedi a FixBot
  11. Samsung Eternity Microphone Replacement: passo 12, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 12, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 12, immagine 3 di 3
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
    Chiedi a FixBot
  12. Samsung Eternity Microphone Replacement: passo 13, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 13, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 13, immagine 3 di 3
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
    Chiedi a FixBot
  13. Samsung Eternity Microphone Replacement, Microphone: passo 14, immagine 1 di 1
    • Pop the microphone up and out of its small housing.
    Chiedi a FixBot
  14. Samsung Eternity Microphone Replacement: passo 15, immagine 1 di 1
    • Peel up the black tape on the bottom of the back case.
    Chiedi a FixBot
  15. Samsung Eternity Microphone Replacement: passo 16, immagine 1 di 1
    • Use the spudger to release the front buttons from the phones frame.
    • Don't try and pull the front buttons completely away from the phone. There are clips that still are holding them to the phone.
    Chiedi a FixBot
  16. Samsung Eternity Microphone Replacement: passo 17, immagine 1 di 3 Samsung Eternity Microphone Replacement: passo 17, immagine 2 di 3 Samsung Eternity Microphone Replacement: passo 17, immagine 3 di 3
    • Use the spudger to remove three plastic lasso hooks that are holding the front buttons to the case.
    • The front button plastic assembly should come right off.
    Chiedi a FixBot
  17. Samsung Eternity Microphone Replacement: passo 18, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Use tweezers to release the button logic board away from the phone's casing.
    • Do not try and completely remove the component. There are logic ribbons that need to be guided through the phone's back casing.
    Chiedi a FixBot
  18. Samsung Eternity Microphone Replacement: passo 19, immagine 1 di 1
    • You should be able to see two cables connected to the front button board.
    • Carefully slide these two cables through their respective holes in the body of the camera.
    Chiedi a FixBot
  19. Samsung Eternity Microphone Replacement: passo 20, immagine 1 di 1
    • The front button board should slide out. At this time you can replace the button/microphone component.
    Chiedi a FixBot
Conclusione
Cal Poly, Team 15-11, Regan Spring 2011 Membro di Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 45
Tutti i Tempi: 2,432
