Salta al contenuto principale
Samsung Epix Keyboard Replacement
Cosa ti serve
  1. Samsung Epix Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Keyboard Replacement: passo 2, immagine 1 di 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Keyboard Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Keyboard Replacement: passo 5, immagine 1 di 2 Samsung Epix Keyboard Replacement: passo 5, immagine 2 di 2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Keyboard Replacement: passo 6, immagine 1 di 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
  7. Samsung Epix Keyboard Replacement: passo 7, immagine 1 di 1
    • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully remove the ribbon.
  8. Samsung Epix Keyboard Replacement: passo 8, immagine 1 di 1
    • Remove the front faceplate.
  9. Samsung Epix Keyboard Replacement: passo 9, immagine 1 di 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
Conclusione
Chris
Membro da: 04/20/11
23 Reputazione
1 Guida realizzata
Cal Poly, Team 15-15, Regan Spring 2011 Membro di Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,664
