Salta al contenuto principale
Samsung Epic 4G Touch microSD Card Replacement
Cosa ti serve
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: passo 1, immagine 2 di 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: passo 2, immagine 1 di 2 Samsung Epic 4G Touch microSD Card Replacement: passo 2, immagine 2 di 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: passo 3, immagine 1 di 2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: passo 3, immagine 2 di 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: passo 4, immagine 1 di 1
    • Pull the microSD card away from its slot.
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
Uhh.... my Australian SGSII looks different to this...
Bonj - Replica
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,376
