Salta al contenuto principale
Samsung Epic 4G Touch Battery Replacement
Cosa ti serve
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Epic 4G Touch Battery Replacement, Rear Case: passo 1, immagine 2 di 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: passo 2, immagine 1 di 2 Samsung Epic 4G Touch Battery Replacement: passo 2, immagine 2 di 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: passo 3, immagine 1 di 2 Samsung Epic 4G Touch Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: passo 4, immagine 1 di 2 Samsung Epic 4G Touch Battery Replacement: passo 4, immagine 2 di 2
    • Lift and remove the battery from the midframe.
Conclusione
Altre 10 persone hanno completato questa guida.
2 Commenti
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - Replica
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 9,703
