Salta al contenuto principale
Samsung Droid Charge SIM Card Port Replacement
Cosa ti serve
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: passo 2, immagine 1 di 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: passo 3, immagine 1 di 1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: passo 4, immagine 1 di 1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: passo 5, immagine 1 di 1
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
  6. Samsung Droid Charge SIM Card Port Replacement: passo 6, immagine 1 di 1
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
  7. Samsung Droid Charge SIM Card Port Replacement: passo 7, immagine 1 di 1
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
  8. Samsung Droid Charge SIM Card Port Replacement: passo 8, immagine 1 di 2 Samsung Droid Charge SIM Card Port Replacement: passo 8, immagine 2 di 2
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Lucas Carter
Membro da: 09/27/12
172 Reputazione
1 Guida realizzata
Cal Poly, Team 15-44, Forte Fall 2012 Membro di Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,394
