Salta al contenuto principale
Samsung DVD-HD850 Player Disk Tray Replacement
Cosa ti serve
  1. Samsung DVD-HD850 Player Disk Tray Replacement, Locate and Remove The Disk Tray: passo 1, immagine 1 di 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Data Strips: passo 2, immagine 1 di 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: passo 3, immagine 1 di 3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: passo 3, immagine 2 di 3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: passo 3, immagine 3 di 3
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Tray Replacement, Disk Tray Removal: passo 4, immagine 1 di 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Tray Replacement, Success!: passo 5, immagine 1 di 1
    • Congrats! You have sucessfully have taken out the disk drive
Conclusione
Carlos
Membro da: 10/16/14
354 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Membro di UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 545
