Salta al contenuto principale
Samsung DVD-HD850 Player Cover Replacement
Cosa ti serve
  1. Samsung DVD-HD850 Player Cover Replacement, Cover: passo 1, immagine 1 di 1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Cover Replacement, Locate and remove screws: passo 2, immagine 1 di 1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Cover Replacement, Remove Cover: passo 3, immagine 1 di 1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
Conclusione
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Membro di UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 394
